How do I get a new comment to show up on a different card?
Jess Sherman
So I set this automation up. I'm trying to get it so when a new comment in this board is added to any card, it'll automatically comment that original comment on the issue "MFDW-390" (so just duplicating any comment onto the specific card MFDW-390)Jira1.PNG
Instead when a comment is added it generates a comment on MFDW 390 that's just a circular reference to itself instead of the original comment...
Hopefully this makes sense! I'm guessing my smart values are wrong... any help would be appreciated!
Fernando Eugênio da Silva
April 24, 2023
@Jess Sherman
Have you tried use this?
Comment by: {{triggerIssue.comment.last.author.displayName}}
At: {{triggerIssue.comment.last.created.format("MM/dd/yyyy")}}
Issue Key: {{triggerIssue.key}}
Content: {{triggerIssue.comment.last.body}}
 You can see more about {{triggerIssue}} here: https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/#--triggerIssue--
Hope this helps.
Fernando
Jess Sherman
You are amazing!! This worked perfectly for me :) Thank you!
Like # people like this
