Hi,I need to get the assignee's email by call the following api,
It return an error message: Requestor must be a whitelisted app (not a user).
I have found the proposed solution that "build a app using Atlassian Connect framework", but I don't quite understand it. Could you please explain how to operate it in detail?
Thank you!
Hi @王悦
Welcome to the Community!
Access to the user's email information is restricted for security reasons due to GDPR. To access the user email information, you will need to build a Jira app using the Atlassian Connect framework and then install the app in Jira Cloud.
Thank you very much!
