How do I get the row count in a Jira query?
Jose Ariel Laureano Ramirez
I want to get the amount of rows returned from a Jira query, just like the count() function that it is used in SQL.
August 17, 2021
Hi @Jose Ariel Laureano Ramirez
Running a JQL statement from the user interface will not show the count when it is above the limit.  However if you call the REST API search method for your JQL the "total" field will show the count.
Based upon your other recent questions/posts, I wonder if this is this for an automation rule.  If so, you may call the REST API from an automation rule using a web request to get the count.  Here is a how-to for making such a call: https://community.atlassian.com/t5/Jira-articles/Automation-for-Jira-Send-web-request-using-Jira-REST-API/ba-p/1443828
Best regards,
thanks @Nir Haimov but I would like to get it via a query so I can say for example: If result is >=100 then do this else do that. Did it make sense to you?
Nir Haimov
It's already written in the filter screen (see attached)
Nir Haimov
Yes, it make sense, if you are running this JQL via external code, i thought you are asking it via Jira UI.
If you are running a JQL via the API: https://docs.atlassian.com/software/jira/docs/api/REST/8.14.1/#api/2/search
you can use the "total" entity, which tells you the count of records...
Like • Sierra Larsen likes this
