I have a team-managed project for which is impossible to see all complete issues. I have some issues done and they just disappeared and I can't make them appear anymore.
I have poked around endlessly trough the complicated and not-at-all user friendly mess that Jira is and I just can't find any option to make all issues appear. Also, there is no "issues" option on the left pane.
How do I make all my issues appear all the time, even when completed (Done)?
Hello @Manuel Malagon ,
Welcome to the community!
I hope enabling issue navigation would ease your work.
Have a great day!
Thanks for helping,
I got the issues navigation by enabling it on the project settings as you say, so that helped.
But I'm not clear on why the DONE issues are not visible on the board. Are you saying that if I just move the right-most column to one before, I can prevent the resolved issues from disappearing? Or are you saying that all Resolved issues will just disappear from the board after 2 weeks of completion?
In any case, is there a setting I can enable to make all issues just stay visible in the DONE board regardless of resolution time?
Hello @Manuel Malagon and @Himanshi ,
I'm also facing the same on the Jira board. I can't see the done issue on board. Does anyone find any solution for the same?
I'm facing same issue
I would also like for Done items to remain on the board regardless of resolution time, considering you cannot change that value so that the item is no longer marked Done such that it does show.
Hi everyone,
This is currently a Feature Request which can be found here: https://jira.atlassian.com/browse/JWMCLOUD-19
I will note, that our Product Manager, Eric, left a note on the ticket earlier this month to say this is not currently on the product roadmap.
We still encourage everyone to vote for and comment on this ticket, as it still may be added to a future roadmap.
Talar
Hi everyone. Jira is great but the lack of this feature makes it pain in the a$$. I have A LOT OF DONE issues that i need to reopen at some time and i cant find it even when i turnet on Issue Navigator!!!
i read the Feature Request here: https://jira.atlassian.com/browse/JWMCLOUD-19
but am confused by the explanaton from atlassian product team. i dont see that there is any workaround (other than creating some hack to pull up. a list) what we want is for Done items to show at same time on same board with all items. If we create another column on the far right (after our current DONE) shouldn't the 2nd to last column (Done) show all items then??
