Hi Everyone,
We're on JIRA cloud and are trying out the ScriptRunner addon. Is it possible to set a custom date picker field with the current date/time in a workflow transition's post function? If so, how would I do so?
By playing around with a test workflow, I think I found what you need:
I have not tested this, but I'm trusting what I read on screen on Step 6 as JIRA shows:
Please make sure that the value you enter is valid for custom field its datatype
and context configuration for the project using this workflow.
Otherwise, the transition may fail at execution time.
Additionally to enter text or numbers as value, you may use the following:
- You may use macro '%%CURRENT_USER%%' to insert the function caller.
- You may use macro '%%CURRENT_DATETIME%%' to insert the current date and time.
- You may use macro '%%ADD_CURRENT_USER%%' to append the function caller. Obsolete please use append option instead with user macro above.
- For Cascading Select fields, you may either use the value of the option to be selected, no need to add the parent for childs. Or simply enter the ID of the option to be selected.
This turned out to be the solution! Thanks!
This didn't work for me I just get an error saying unable to update custom field.
I have tried using a date picker and a single line text field. Neither work?
Hi. Does anyone know of a way to do this for a future date. I want to automatically populate with current date + 2 weeks upon transition. Thanks.
@Lexi Pike you would have to do it with a scripted post function with something like script runner
@Lexi Pike Just occurred to me that you can probably use the jira automation feature to set it if your instance has it available or if you're on cloud. It allows for smart dates that you can assign offset dates to fields on. It's slightly technical but all point and click with text boxes to do.
Trying to figure out how this could work with creating Issues through an URL/LINK
No problems to select the project or the issuetype but it is tricky to set the due date to today or tomorrow or today plus 10 days...
Step 4 mentions "Update Issue Custom Field". That's not available on our Community server-based version, or is perhaps a configuration issue? I see only "Update Issue Field" (desc: Updates a simple issue field to a given value) and I would like to edit a custom field (date picker) and the custom field does not appear in the drop down of applicable fields.
Thank you Jon! As I am still new to ScriptRunner: What would be the correct way to update a custom field in a scripted post-function when using a Jira Server?
Marco, refer to Vasiliy Zverev 's answer in this thread for the server solution.
What do you enter for Timestamp?
Here is code for custom script post-function:
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.event.type.EventDispatchOption import com.atlassian.jira.issue.MutableIssue import com.atlassian.jira.issue.UpdateIssueRequest import java.sql.Timestamp issue.setCustomFieldValue( ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("customFieldname") , new Timestamp() ) //only for create transition /* ComponentAccessor.getIssueManager().updateIssue( ComponentAccessor.getJiraAuthenticationContext().getUser() , issue , UpdateIssueRequest.builder().sendMail(false).eventDispatchOption(EventDispatchOption.ISSUE_UPDATED).build() ) */
This answer is for server, not cloud
But for server, you should not need the commented out bit even on create.
The custom field updation using the post function as depicted above works for cloud JIRA too.
How do I know what is the process flow I'm working on . ? I'm using a nextgen project but now sure what is the workflow I;m using.
I dont have script runner.
I want only the month to be updated in the custom field. Is there any macro similar to %%CURRENT_DATETIME%% available for the same.
Could there be any solution, either a direct macro for month, or to extract only the month part from the datetime, and populate it to another custom field.
Vinay
What you want to do isnt possible without add-on's
Vinay
There isnt.
Edit your workflow, add new post-function on the action of type "Script Post-function".
Choose "Modify Issue" function.
Enter the following code:
issueInput.fields.customfield_10132 = new Date().format("yyyy-MM-dd")
where 10132 is the ID of the custom field you want to update.
You'll be better off using a ZonedDate to make sure you get the date in the correct timezone:
issueInput.fields.customfield_10132 = ZonedDateTime.now(ZoneId.of("UTC")).format(DateTimeFormatter.ISO_LOCAL_DATE)
I'm getting this error now. Is there any way to set this field without having to surface it on my screens? I'd rather not allow users to change this value.
2016-11-21 19:09:28,388 INFO - Serializing object into 'interface java.util.Map' 2016-11-21 19:09:28,390 INFO - PUT /rest/api/2/issue/80258 asObject Request Duration: 326ms 2016-11-21 19:09:28,403 ERROR - assert resp.status == 204 | | | | 400 false status: 400 -` Bad Request body: [errorMessages:[], errors:[customfield_15500:Field 'customfield_15500' cannot be set. It is not on the appropriate screen, or unknown.]]
I use version 3.0.6 of ScriptRunner. The above mentioned script fragment
issueInput.fields.customfield_11100 = new Date().format("yyyy-MM-dd")
didn't throw an error but it did not have any visible result. Does it work for my companies old version of ScriptRunner?
Marco - that code snippet will only work for Jira Cloud.
If you have version 3.0.6 of ScriptRunner then you are using Jira Server.
Randy - apologies for the extremely slow reply but yes you can.
The Jira Cloud REST API docs state you can use the overrideScreenSecurity query parameter as long as your script is being executed by the ScriptRunner Add-on user.
Thanks Jon!
