I need to get a issue current status via api, i'm using the endpoint
Hello @Cesar Bastos
Exactly how is it not working? What value or error message are you getting?
Have you tried dumping the JSON output to find if the Status field is included?
Hi @Trudy Claspill , it brings me a big response. I just need the status name, but when i tried to get this in JSON.parse(response).issues.status.name it returns me a null value
Can you share the solution so that other community members can benefit from what you've learned?
