Sign up Log in
How do i see which projects a Group has access/permissions/roles assigned to.
Paul Fechner
I have a Group which i think is not used and would like to delete it.
Is there a way I can confirm it is not used within any projects?
6 votes
Kerli Loopman
Has anyone ever came up with a solution or workaround for that in Cloud?
I am really struggling to manage groups that might not be in use anymore, it is not reasonable to check all Confluence Cloud space and pages restrictions, projects access, filters and dashboards shares, permissions schemas, automations manually before removing the group.
Shahroz Naeem
@Paul Fechner did you ever find an answer? I'm currently reviewing the accesses as part of a security audit and this would really help in that.
Ismail Sanni
Hi @Paul Fechner
I think you can only see the group's members and their product access, but there should be way to check.
Rilwan Ahmed
January 28, 2022
@Paul Fechner
Here is the solution: https://confluence.atlassian.com/jirakb/how-to-identify-group-usage-in-jira-441221524.html
Replace ('helpdesk', 'administrators') with a comma-separated list of the groups you want to check for usages
John Funk
January 28, 2022
Not sure that applies to Jira Cloud though.
Like # people like this
Rick Westbrock
That article definitely doesn't apply to cloud since all it does is provide SQL queries and of course we don't have direct database access in the cloud.
Giampiero Celluprica
I have seen that there is a feature request suggesting the implementation of this ability:
https://jira.atlassian.com/browse/JRACLOUD-71967
Please, click on vote and watch to receive updates about the feature.
