How do we filter stories which are without Sub-task by using JQL?
Anh Le
I searched and found some old answers but wonder whether there is any solution without using the plugin?
Muhammad Ramzan_Atlassian Certified Master_
November 15, 2020
Unfortunately till now , no luck without plugins.
Just updating my answer, here is the plugin  JQL Search Extensions for Jira & reports  example if interested to use
type = story and subtasksCount < 1
Anh Le
The problem is, I'm using JQL in Google Sheets add-on. So I cannot use plugin.
Daniel Turczanski - JQL Search Extensions
Hi Anh,
JQL Search Extensions is our app and it integrates well with Jira's native search. Feel free to reach out to our support for help. Thanks!
Alexander Bondarev
December 30, 2020
Hi, @Daniel Turczanski - JQL Search Extensions !
Thank you for the app, it is really useful!👍
Alexander Bondarev
November 15, 2020
Hi, @Anh Le !
Like told @Muhammad Ramzan_Atlassian Certified Master_ this is not possible.
Here you can check all the available JQL features in the Jira Cloud.
Anh Le
