I am surprised that in JIRA project from the Project Management area, not a sprint, I can't find a gadget to display all open tasks, all tasks that are in progress, and then tasks that are labeled as done or completed... I have tried the created vs resolved gadget and that does not work even with tasks marked as done. Any help here would be appreciated, Thanx!
Hi @Douglas Carter ,
You can use pie chart or issue statistics gadgets and choose statistic type as status. so you can see all the tickets of their respective status
Hi Douglas,
I would create a filter that shows all of the issues in your project - something like: Project = ABC
Save and share that with anyone that needs to see the data in the dashboard.
Then create a dashboard and use the Issue Statistics gadget. Use Status for the Issue Statistic.
That should get you want you need.
