Does Jira calculate Epics % complete by stories completed and/or story points complete?
Is there a story %complete? Task done or hours spent?
Use: I want to show Epic completion on a Roadmap where completion is based upon number of stories complete and at the story level have story %complete be based on tasks done.
In short Task Done rolls up to Epic %complete.
Watch my video to know how you can calculate epic progress % using jira automation
Does anyone have a solution to using the % Done value in an Epic in reporting since it doesn't show up as a field? I'd love to be able to utilize this value in reporting from other products (i.e., Confluence) but since it's not a field, it doesn't show up. Any ideas?
After calculating percentage through automation you can use the filter gadget and the % info you can select the field in the gadget
Hello Devin,
The % complete for Epics is based on the number of associated issues on the Epic that have a status category of "Done". For example, if an epic has 1 story and 3 tasks linked to it, then all 4 carry equal weight, and would need to be in a "Done" status category (green status in your Jira workflow) for the Epic to say 100% complete, regardless of the story points/time estimates on each issue).
I'm not aware of a story % complete, or a similar feature that's native to Jira. Might need a marketplace app.
Hope this helps
@Sam Nadarajan - can you get the information you have above on a dashboard with a native gadget? I am wanting to show all Epics for a project that have the percent complete for each Epic.
