How does an issue get into a version?
rhonda
September 2, 2021
We have a planned version and a fix version field  - which one places an item in a release?
Jack Brickey
I expect planned version is something that was added by your admin upon request. Likely the intended requirement is that the development team fills in a plan version and then once it’s actually fixed they place the actual version where the issue was fixed into the fixed version field. Releases are associated with the fix version field.
Italo [Modus Create]
There are two fields in JIRA where you can use Versions
  • Fix Versions
  • Affects Versions
Read more in this documentation
Trudy Claspill
Fix Version
If you look at the Releases screen and drill into a specific Version, the issue statistics shown there are based on that Version value being in an issues Fix Version/s field.
