How many times has a task been Restarted?
Scott July 11, 2023
Our workflow includes a status of "Restarted". "Restarted" status is assigned when a task has been Peer Reviewed or tested and found to have some defect.
How would one create a report to determine how many tasks have had a status of Restarted or how many times a task has been marked Restarted?
3 accepted
Valeriia_Havrylenko_SaaSJet
July 12, 2023 edited
Hello @Scott 👋
As an alternative , I guess you can try Time in Status (developed by my SaaSJet team) with 7 types of status time reports
For your exactly need we have Status Count report or Transition Count report
The Status Count report shows how many times an issue has been in each status.
Chart view of report:
The Transition Count report shows how many times an issue has moved between all statuses in the workflow.Transition Count report.png
Add-on has a 30-day free trial version and free up to 10 users
Please, let me know if you have any questions
Hope it helps 😌
Emre Toptancı _OBSS_
Hello @Scott
If you are OK with using a marketplace app for this, our team at OBSS built Timepiece - Time in Status for Jira for this. It is available for Jira Server, Cloud, and Data Center.
Time in Status mainly has several types of time reports (showing how much time each issue spent on each status, assignee, or group) but the app also has Status Count and Transition Count reports. These reports show how many times each status and each transition was used by each issue.
For all numeric report types, you can calculate averages and sums of those values grouped by the issue fields you select. The ability to group by parts of dates (year, month, week, day, hour) or sprints is particularly useful here since it allows you to compare different time periods or see the trend. (The screenshot below shows a trend report sample for durations but you can do the same for status or transition counts)
The app calculates its reports using already existing Jira issue histories so when you install the app, you don't need to add anything to your issue workflows and you can get reports on your past issues as well. It supports both Company Managed and Team Managed projects.
Time in Status reports can be accessed through its own reporting page, dashboard gadgets, and issue view screen tabs. All these options can provide both calculated data tables and charts.
And the app has a REST API so you can get the reports from Jira UI or via REST.
Gadget_AverageStatusDurationByComponent.png   tisCloud_StatusDuration_LeadTime_Chart.png
Using Time in Status you can:
  • See how much time each issue spent on each status, assignee, user group and also see dates of status transitions.
  • Calculate averages and sums of those durations grouped by issue fields you select. (For example, see average InProgress time per project and per issue type.)
  • Export your data as XLS, XLSX, or CSV.
  • Access data via REST API. (for integrations)
  • Visualize data with various chart types.
  • See Time in Status reports on Jira Dashboard gadgets
EmreT
Mehmet A _Bloompeak_
Hi @Scott
You can try Status Time Reports app developed by our team. It mainly provides reports and gadgets based on how much time passed in each status.
Here is the online demo link, you can see it in action and try without installing the app. For your case, you can have a look at Status Count And Entry Dates report. Entry date(see In Development, Ready for Testing, In Testing, In Development columns.) is status transition date and status count(see #In Development, #Ready for Testing, #In Testing, #In Development columns) is how many times an issue is entered to this status.
For more detail, you can have a look at Status Time Reports How to Videos.
  • This app has a dynamic status grouping feature so that you can generate various valuable reports as time in status, time in assignee, status entry dates and status counts, cycle time and lead time, average/sum reports by any field(e.g. average in progress time by project, average cycle time by issue creation month).
  • You can search issues by Project, Issue Type, Status, Assignee, Issue Creation/Resolution Date(and any other Date field) and JQL Query.
  • Status durations are calculated according to the working calendar you define. Once you enter your working calendar into the app, it takes your working schedule into account too. That is, "In Progress" time of an issue opened on Friday at 5 PM and closed on Monday at 9 AM, will be a few hours rather than 3 days.
  • You can set different duration formats.
  • You can export reports in CSV file format and open them in MS Excel.
  • You can also add this app as a gadget to your Jira dashboards and reach “Status Time” from Issue Detail page.
  • You can enable/disable access to Status Time reports&gadgets and Issue Detail page per project, users, groups or project role.
If you are looking for a completely  free solution, you can try the limited version Status Time Free.
Hope it helps.
Register now
