Hi @VRaoballa ,
Basically workflow will be inactive until you associate them with a workflow scheme, which can then be associated with a project.
Please refer below documentation on activating workflow and managing workflows schemes,
https://confluence.atlassian.com/adminjiracloud/managing-your-workflows-776636587.html
Avinash
HI,
I have done exactly as mentioned by you, and it had worked fine for my projects.
But today for one project, even after linking the workflow to a workflow scheme; the workflow is showing as inactive.
Hi @Pranita Warik ,
Can you please check whether workflow scheme is mapped to any projects or not.
Avinash
Register today
