Kindly help, how to Add Assignee & Labels to Sub-Task using REST API
Hi @rizky aryansyah and welcome to the community,
Try the following JSON:
"fields": {
"assignee": {"id":"5f9fb7c1c2e5390077abf628"},
"labels": [
"bugfix",
"blitz_test"
Hi @Alex Koxaras -Relational- , thank you for the quick answer. It Works ! Now i can add Assignee & Labels.
Thank you.
Good to know, and I'm glad to be able to help you! Kindly mark my answer as accepted in order to help others with similar question. Thank you!
