×Based on assignee filed how to auto fill developer user picker filed
Hi @AKhil kola
You can use Jira automation or a workflow post function (if you have an app like JMWE).
With jira automation you can create a rule which triggers on issue create, and then add the if/else component to populate the developer field based on the assignee.
Hi Alex,
i am giving you same condition but new action component what i am select???
Edit Issue and then find the field of Developer
Yeah Alex when i am selecting developer filed there is no assignee value. only i am getting some users list's based on user list how can add assignee??
@AKhil kola I'm a bit confused as to what is it that you want to achieve. On your post you state:
But on your last post you state:
So what is it that you want to achieve?
@Alex Koxaras -Relational- When i am using the edit issue in developer filed auto populated not working
@AKhil kola I am so sorry, but I can't understand what you want to achieve. Can you layout your requirements? Or simply paste an image of your rule of what you are trying to accomplish?
