×I am trying to reassign all Cases that are in a Sprint to a particular Release Version (the Fix for Version field)
But when I do an advanced query and choose bulk change, the "Fix for Version" is not listed.
I also searched the page (Control+F) for Fix, Version, Release. No luck.
Problem was that I had Cases from multiple Projects. Fix For (release) is project specific. So can't assign cases from different projects to any Release.
Thus, Jira didn't include that as one of the Fields to modify.
I confirmed by filtering on one project and doing a Bulk Change. It then gave me the Fix For Version.
Fix version should be available when bulk editing issues. If you don't see it, most likely you don't have the resolve issue permissions or the fix version is not on the edit screen. Can you check these two?
Hi @Clay Nichols
@Alex Koxaras -Relational- is right.
Also, I don't know if it's the case, but if you have the Advance Roadmap feature, you can edit through the Plan, filtering the sprint that you want, marking the checkboxes and clicking on Bulk actions>Release
Thx. I was looking for Fix Version/s: not releases....Now it working =)
