How to Export Issues from Jira Cloud (Next Gen Project)
Robert Edyvean November 5, 2020
How do I export issues from a Jira Cloud Next Gen project? I tried to install Jira for Cloud Excel but the links take you to the Microsoft portal without any further link, I don't need to export as Excel particularly, CSV would do fine...
Alexis Robert
Hi @Robert Edyvean ,
if you only need to export as CSV, you can do this by going to the search menu, searching for your issues and then exporting as CSV.
You can have a look at the documentation here : https://support.atlassian.com/jira-core-cloud/docs/work-with-search-results/
Let me know if this helps,
--Alexis
Perfect thanks!
John Funk
Hi Robert - You can create a filter for the issues you want to see. Then you can export from the filter.
