How to I create a post function when an issue is created
Michael
I looked at the documentation for post functions, but I can't seem to find out how to create a post function that fires when the issue is created.
I am using a plugin called Sub Task Manage and I want a sub task created when an issue is created.
How do I create a post function for issue created?
4 votes
Nic Brough -Adaptavist-
August 31, 2016
I'm not sure if your question is about using post-functions or literally adding them to the system.  Post functions are chunks of code you run during a transition.  Some are built-in, and add-ons can provide more.  The workflow basically has a library of them that you could use.
To add a function to the library, you'd find or write an add-on and install it via the add-on manager.
To use one, you edit the workflow, find the grey "start" circle, and click on the transition out of it to highlight it and bring up the info box, and that box will contain a link to "post-functions" which you can then add to, pulling the ones you need from the library
Stefan Arnold
September 1, 2016
When you use the text mode of the workflow when editting you cant see the "Create-Transition".
To see this you have to switch to diagram mode.  There you can choose the Create-Transition and on the right you can see the buttons for post-functions and validators. I made a screenshot how this looks:jira_createPostfunction.png
September 1, 2016
That's not true.
In text mode, click on the first step to see the details for it.  In the display above, you'll see a list of all the transitions into and out of the step
Create is one of those.
It's not displayed in the main list of steps, true, but you don't need diagram mode to get to it.
Stefan Arnold
September 1, 2016
Okay, learned something new wink thanks!!
Never clicked on the step name before^^
Help us plant more trees
