How to Integrate Manage engine service desk plus and jira (bi directional communication)
Hi @BHANU TEJA , I am unfamiliar with manage engine service desk. You might check the Atlassian Marketplace for Zoho connectors. Alternatively consider using the Atlassian APIs for JSD. Integration comes down to your exact requirements. Simple integration might be achieved using email creation and Automation.
Hi @BHANU TEJA
There is documentation on how to integrate on the service desk plus side, see
https://help.servicedeskplus.com/jira-integration
You can also look at this community post from a while back where the same question has been asked.
