How to Map new workflow with Project
Tech Admin - SK Finance Limited January 23, 2025
Dear team,
We need your help for, how to Map new Workflow with My projects.
Because we need a multiple project.
2 accepted
Izabela França
January 23, 2025 edited
You have a team-managed project, so you must follow the steps in this documentation here:
https://support.atlassian.com/jira-work-management/docs/how-to-create-workflows-for-team-managed-projects/
Go to Project Settings > Issue Types > Select the issue type > Edit Workflow.
Note: for team-managed projects, it is not possible to share workflows as we do in company-managed project.
Let me know if it works.
Hi team, Screen shots has been shared
Izabela França
Hello, @Tech Admin - SK Finance Limited . I hope you are doing well.
To add a new Workflow to a project you have to go to Project Settings > Workflow. You can add existing workflows, edit your current one or change your workflow scheme.
Here is an Atlassian Documentation showing the steps to create, edit and associate new workflos to a project.
Note: if you want use the same Workflows in multiple projects you can use the same Workflow Scheme sharing it among them.
I hope it helps. :)
Hi Team,
I have go to in project setting but workflow not showing
Izabela França
Hi, @Tech Admin - SK Finance Limited .
Is your project company-managed or team-managed?
You can check this info at the bottom of the menu on the right:
Dear Team,
Please find the required screenshots ans suggest for the same
Tech Admin - SK Finance Limited January 27, 2025
How to create new workflow in Jira Std
Izabela França
January 27, 2025 edited
I will share with you two Atlassian documents that show you how to create new workflows:
- In team-managed projects (this is the one you are using according to screenshot you shared): https://support.atlassian.com/jira-work-management/docs/how-to-create-workflows-for-team-managed-projects/
- In company-managed projects: https://support.atlassian.com/jira-work-management/docs/how-to-create-workflows/
