Existing Group Name
@Dhanush D You can now rename groups from the new admin.atlassian.com experience. More details are here: https://community.atlassian.com/t5/Atlassian-Access-articles/Org-admins-can-now-rename-groups-in-cloud/ba-p/2276321
Changing group names in Jira doesn't have to be a hassle. With Group Master for Jira, it’s quick and easy! It just helps keep things organized with minimal effort.
If you need a hand, give it a try!
https://marketplace.atlassian.com/apps/1236395/group-master-for-jira?hosting=datacenter&tab=overview
And other advanced group management capabilities:
Si
Hi @Si Van Tran , please review the partner guidelines regarding identifying yourself as being a vendor and necroposting.
Hi
It's not possible directly. You could do some works from the database but it's not recommended. The best option here is to create another group with a new name, add users to it, then set this group in all of the permissions and notifications schemes and automation.
Unfortunately this is not possible. You might wish to read more in the open issue below and while you can and should vote for it understand that it is a very old suggestion.
note that there is a cloud version of that issue but it is under the ID project.
