×I made some changes in Workflow schemes for projects which is
( A condition, where after a certain stage movement Changes cannot be done in Tickets only able to add comments).
Now how can i revoke this changes back to default.
Need help ASAP!!!!!!!!
Hey Yash,
Just take out the change and re-publish your workflow.
Hi @Yash Pradhan ,
If the workflow is not published, just discard it. Any changes made will be removed.
If its published, then do as @John Funk mentioned.
