How to Search for Issues with a Specific label
Jyothi Ravipati June 3, 2022
Hi Team,
I would like to search for Issues with a Label "Product_Blockers" . When I used the query -
labels in ("Product_Blocker") AND updated >= -90d . It was displaying current Issues which hold that label.
But what I required is the total number of Issues passed by that Label, Like
as once the product dependency is done, the product manager removes the label.
so if we want to know how many product manager dependency tickets we had in last 90 days…..we will miss the count.
Thank you in Advance.
Oliver Siebenmarck _Polymetis Apps_
HI @Jyothi Ravipati ,
Getting historic data is possible, but not easy – certainly not in JQL queries.
I would therefore recommend changing your process a bit, so that whenever the "Product_blocker" label is removed, a new label like "was_once_a_product_blocker" is added.
You could ask your product managers to do that manually, but I believe it will be better to use an Automation instead. That way, nobody has to change what they are doing today and you can simply use a JQL query like
labels in ("was_once_a_product_blocker")
Hope that helps,
 Oliver
P.S. As for setting up the Automation rule, I'd do it like this:
Trigger: Field value changed (label field)
Condition: Check {{fieldChange.from}} for the presence of the "Product_blocker" label
Action: Add the "was_once_a_product_blocker" label
I'm certain other approaches would work just as well. Happy labelling!
Antoine Berry
Unfortunately this is currently not possible (see this ticket). Maybe you could use an additional status or a specific issue link to track these issues ?
Jyothi Ravipati June 6, 2022
Hi @Antoine Berry
How can I use Issue Link for this specific Use case and Found out Issues?
Antoine Berry
Hello @Jyothi Ravipati ,
I thought you could use an issue link like "Blocks" <-> "Is blocked by" to track the issues you want.
But you would not be able to retrieve them after deleting the issue link.
So maybe solution would be to use an additional status since you can track issues transitioned to a specific status during a specific period.
