How to add a table in to Jira issue template in a Next Gen project?
Tom Holt
June 16, 2020
We need to format one of the fields in template as a table but I can't see how to do this?
This is a really critical feature if you are trying to document structured requirements, e.g. documenting event tracking requirements etc. Free text is no good for this.
I get that you can add tables in to the tickets themselves but that means they need creating each time.
Is adding tables to templates on the backlog?
If not, would you be bale to add it as I think others would find this useful too.
3 votes
Angélica Luz
June 17, 2020
Hello Tom,
Testing on my local site, I wasn't able to add a table to the Description field as default value as well.
Using the shortcut or copying/pasting the table to the default value also doesn't work.
With that said, I created a feature request based on your question:
Please, click on vote and watch to receive updates about the feature.
Angélica
Tom Holt
June 18, 2020
Thanks Angélica, I will keep an eye on the progress of this ticket.
Like Angélica Luz likes this
4 votes
Alex Chen
Still no table available for default description after two years!!!
Nour Durra Nagarro
Hi @Tom Holt
I found a workaround that might help until atlassian implement the fix, adding the following Table values as a default in any Text area (with wiki rendered) will work after creating the issue
||Table Header 1||Table Header 2||
|Col A1|Col A2|
check the screens for an implemented example:
Screenshot 2021-07-22 at 19.14.41.pngScreenshot 2021-07-22 at 19.14.58.pngScreenshot 2021-07-22 at 19.15.24.png
Atlassian TalTech
October 26, 2021
Does this workaround also work in DataCenter platform?
Zaldy Parian
June 20, 2023
Hi @Nour Durra Nagarro ,
Could you please help us with the solution steps? It doesn't seem to work with me. What I did so far was...
Created a custom field named 'Table field'. It has following configuration:
I then navigated to Field configurations left-panel menu, and searched for Table field field name. Then click on Renderers option at the right end:
From that page, I selected Wike Style Renderer
But when I create a new issue, the field has this default value:
It doesn't appear to be a table grid where users can add text inside the table.
Did I miss something? What was I doing wrong?
Hope you could help.
Thanks.
Francesco Carullo MMS September 30, 2024
Hi @Nour Durra Nagarro and @Zaldy Parian , I tried the same but it doesn't work, any advice? Thanks
