How to add a watcher to a sub-task in Jira Automation?
Leon Gumba
Hello!
I am creating a scheduled automation rule that creates a task in my project, and I need to create a sub-task for it right from the start. I want one of my colleagues to be added as a watcher, but only for that specific sub-task, not for the parent issue.
How can I achieve this? I can't create a nested branch (branch within another branch), and when I try to add a branch for sub-tasks, I get this error:
"This component may be incompatible. One of the following needs to be produced earlier in the rule by the trigger or with a 'for each' branch for this component to work: Issue."
Any idea how to work around this?
2 accepted
3 votes
Manoj Gangwar
Hi @Leon Gumba  You can change the Branch by selecting the Children option or you can use the JQL option.
Leon Gumba
Hi @Manoj Gangwar , and thank you for your response!
Unfortunately, the Children branch option also produces the same error.
However, the JQL branch option worked! I was able to find this topic and it was really helpful:
https://community.atlassian.com/t5/Automation-questions/Adding-watcher-to-subtasks/qaq-p/1939011
It is suggested to create variables before using JQL, which made the rule run smoothly.
Like Manoj Gangwar likes this
Doreen Undiri
October 28, 2024
@Leon Gumba using JQL option as Manoj mentionedScreenshot_20241028_174831_Samsung Internet.jpg
Doreen Undiri
October 28, 2024
@Leon Gumba use the following JQL( parent = {{createdIssue.key}} AND issuetype = "Sub-task")  without the brackets
Like Leon Gumba likes this
Leon Gumba
@Doreen Undiri thank you! Your solution works perfectly, and there's no need for variables. Just tested it, and it works like a charm.
Like Doreen Undiri likes this
October 28, 2024
Hi @Leon Gumba
I believe there are at least four ways to do this with an automation rule:
  1. With your current rule structure, add the Watchers by calling the REST API endpoint using the Send Web Request action, rather than with Manage Watchers
  2. To create the sub-task, do not branch to the Most Recently Created Issue.  Instead create the issue in the main rule path, setting the Parent field to {{createdIssue.key}} and then branch to Most Recently Created Issue (for the sub-task) to use Manage Watchers
  3. Combining #1 and #2, add the Watchers with the REST API endpoint rather than branching
  4. Using multiple rules, with the second one triggered by the issue create and checking the issue type (and other conditions) to decide when to add the Watchers
