Hi @sai reddy,
Team-managed projects doesn't allow you to set field permissions, and in order to do it in company-managed projects you would have to use an app for it, like Protected Fields or Secure custom fields.
Hi @Mikael Sandberg ,
Thank you for your response. For Company managed projects how we can set permissions on Label based custom fields? I checked above apps but they are not supporting label custom fields.
Thank you again,
Sairohit
If they do not support label fields, you are sort of out of luck. I would reach out to the app vendors and see if they have any plans on supporting label fields.
