How to add emojis to ribbon shortcut name?
Martens_S
April 6, 2020
Hi!
When adding a shortcut to the projects main (vertical) ribbon it should be possible to add an emoji. Until now I am not able to do so (except the one shown in the example). It seems you can only add one particular type of emoji graphic.
The ones from the list on this official page do not work.
Does anyone know if there is a particular list to use?
Thanks in advance!
Sander Martens
Martens_S
April 6, 2020
Ha, found https://emojipedia.org/ to work just now...
Jose D'Agostino
July 15, 2020
Hello, I found the solution in this thread: https://community.atlassian.com/t5/Jira-Questions/Emojis-in-JIRA-Issue-Summary/qaq-p/1010469
It basically tells you to add the emoji (no its codename) into the text field by right clicking on it and selecting Emojis in Chrome menu options. I was able to add the shortcut's icon with this.
I hope it helps!
