×Hi there
I have several automation rules that used advanced branching to create multiple issues based on unique values (labels on a triggering issue)
branch looks like:
Smart Value
{{#issue.Labels}}{{.}}, {{/}}
Variable Name
UniqueIssue
for each issue that I create (so each UniqueIssue) I'd like to be able to take the position of the label being iterated on (the respective Label) and add it as a label to the newly issue giving me labels of 0 1 2 etc on each respective issue. I've been unable to find a way to get just one index label on each issue instead of all 3 of them (ie separate labels of 0 1 and 2). Any suggestions?
ideal output from the would be three issues
UniqueIssue1 with a label of 0
UniqueIssue2 with a label of 1
UniqueIssue3 with a label of 2
Tried using something like this in advanced edit but it gives me 3 labels per issue
"update": {
"labels": [{{#issue.Labels}}{"add": "{{index}}"},{{/}}
Even just getting the "0" label on the first issue created through the loop would actually be the best case scenario.
Also have the same question, does anyone know how to do it?
