How to auto format number fields using scriptrunner
Scott Federman February 8, 2022
Is it possible to auto-format a number field in scriptrunner?
Ex:
Cap: 12.335 should be 12.34
Cap: 12.3 should be 12.30
Cap: 12 should be 12.00
Pramodh M
Hi @Scott Federman
Can you try this and let me know if this works?
def cap = 12.335
cap = ((float)cap).round(2)
println cap
Pramodh
Pramodh M
If you really need that 0 after a decimal
Convert the number to string and append zero
how would i do that? would i need a text field vs number field?
Pramodh M
Here it is @Scott Federman
Let me know if this works
def cap = 2.34
cap = ((String)cap)
str = cap.split("\\.");
if (str[1].length() == 1)
cap = ((String)cap) + "0"
println cap
Scott Federman February 9, 2022
@Pramodh M it returns this error "The scripted field ran successfully, but returned an invalid type. Please return a number" There is only a number in the field
Pramodh M
Hi @Scott Federman
If you are returning a number, 2 zero after the decimal is not possible
You need to use this
def cap = 2.34
Yeah no joy there either. This is for cloud?
Pramodh M
@Scott Federman
May I know what is the error?
Scott Federman February 10, 2022 edited
@Pramodh M i converted this to a text field called Cap-test. Changed the script to
def cap-test = 2.34
cap-test = ((float)cap-test).round(2)
cap-test = ((String)cap)
str = cap-test.split("\\.");
cap-test = ((String)cap-test) + "0"
println cap-test
and returned this error
