How to automate a date calculate between two custom field values
Brian Taylor
I have a use case for which automation would work, but I need to see if it is possible to calculate a date field between two fields.
I have a date field called Renewal Date, and a secondary field is a dropdown field that shows the time for the next renewal (i.e., 6 months, 1 year).
I want to clone the issue to a new issue but update the Renewal Date to take the existing renewal date and add 6 months or 1 year based on the dropdown value.
February 13, 2025
Hi @Brian Taylor
Adding to the suggestion from @Manon Soubies-Camy ...
I recommend using a Lookup Table for this scenario.  There is even an example in the documentation which nearly matches what you need for a date increment based upon a selection value.
https://support.atlassian.com/cloud-automation/docs/jira-automation-actions/#Create-lookup-table
This would eliminate the need for an if / else condition block to compare values, replacing them with a single get() call.
Manon Soubies-Camy
Hi @Brian Taylor,
Here's a similar use case where:
  • I'm updating Due date instead of Renewal date.
  • I'm relying on the Description instead of a dropdown field, but the same logic would apply.
Below are the smart values I used:
  • To add 6 months: {{triggerIssue.duedate.plusMonths(6)}}
  • To add 1 year: {{triggerIssue.duedate.plusYears(1)}}
Hope this helps!
- Manon
Register here ⬇️
