How to automate any task of internal project related to leaves as when user update his work logged for the task, a notification should be sent to the project managers of that project for approval of that work log.
Hi @Shasheekant Patel, if I understand your question correctly you might try something like this using Jira Automation:
Update the filter (yellow) and the email recipient and content (blue) according to your need.
TimK.
