How to automatically assign an issue to only one person in a an project?
Abdul Samad March 31, 2022
I want to create a workflow of user access management. i have created the workflow i have created an issue type as well and the screens and fields according to this task. now i only want, when any one wants to request an access the assignee should automatically be one person and the reporter should not be able to change the assignee.
Suvradip Paul
March 31, 2022
@Abdul Samad ,
Thanks for posting and welcome to the community.
As @Nic Brough -Adaptavist-  suggested above using Jira Automation it can be done easily. Please try from if you are still facing any issues, post here.
March 31, 2022
First, check the permissions in the project - take away the permission to assign issues from anyone who should not be able to change the assignee.
Second, add a post-function to the workflow for that issue type, one that sets the assignee to the person you want.
I only want this to be done in only one issue type and rest of them to be default
@Nic Brough -Adaptavist-  and @Suvradip Paul  thank you for your guidance it worked
Like • Nic Brough -Adaptavist- likes this
