How to automatically sum or count the values from 2 or more fields?
NORBERTUS WUSANA
2 accepted
Fabio Racobaldo _Herzum_
December 5, 2022
Hi @NORBERTUS WUSANA ,
as @Gaurav said you can sum number fields through an automation. Here a similar question with example https://community.atlassian.com/t5/Automation-questions/Sum-numeric-values-from-a-custom-field/qaq-p/1757732
Here smart values examples https://support.atlassian.com/cloud-automation/docs/jira-smart-values-math-expressions/
Hope this helps,
Fabio
Gaurav
December 4, 2022
Hello @NORBERTUS WUSANA
This is possible using Automation natively. The rule can be defined to be triggered when the value on either of the values changes and add the required values to update the 3rd field.
Hope this helps.
--GG
Marta Woźniak-Semeniuk
December 5, 2022
Hey @NORBERTUS WUSANA as people said above you can use the automation, but the right choice of what you use depends on what exactly you want to sum up and where/when?
