Hi everyone, I was wondering if it is possible and how to do this if possible.
In our Jira Cloud instance we have 4 Priority values which are "No Priority Set", "P3", "P2", and "P1".
I am wondering if it is possible to somehow block a transition (specifically the "Create issue" transition) if the value of Priority is "No Priority Set" without using plugins and using a validator.
I am aware that there is a Condition that can do this, but the "Create issue" transition does not have an option to add conditions. Maybe some workaround could be implemented?
Not that I know of using native functionality.
I'd recommend either...
Let us know if one of these options works for you!
Ste
Thank you for the suggestions. This looks like a great workaround.
I will check if this works for the team.
Yes, you can do this natively.
First, remove the "no priority set" option from the priority list. It does not make sense because it is a priority, so you are setting the priority, but saying you have not.
Second, in the project(s) that need it, make the priority mandatory.
