Hi Team,
I have created a task where i want Due Date to be non-editable and if required to edit the dates user should be notified to create a Sub-Tasks with edited dates.
Can you please help me with the solution.
Thanks in advance!
If you want to set due date only on create screen, you can just remove the field from edit screen so that it becomes non-editable and add field to View Issue screen for visibility.
Aditya
Help us plant more trees
