How to block transition when two user pickers are same
Lily Wang October 22, 2021
I want to block the transition when the two user picker fields are same. But the jira expression seems always be wrong.
issue.customfield_12702[0].accountId != issue.assignee.accountId
It will always show this:
Message:
Evaluation failed: "issue.assignee.accountId" - Unrecognized property of `issue.assignee`: "accountId" ('accountId'). Type null does not have any properties
Can anyone help me ?
Tks in advance.
David Fischer
Hi @Lily Wang ,
what is the type of custom field customfield_12702? Single or multi-user picker?
If it's a Multi-user picker, then the right expression is:
!issue.assignee || !issue.customfield_12702 || !issue.customfield_12702.some(it => it.accountId == issue.assignee.accountId)
If it's a Single-user picker, then the right expression is:
!issue.assignee || !issue.customfield_12702 || issue.customfield_12702.accountId != issue.assignee.accountId
John Funk
Hi Lily,
Where are you trying to execute the code?
Lily Wang October 24, 2021
Hi, John:
I just use the validator.
Build-your-own (scripted) Validator (JMWE app)
John Funk
Read the story
