How to bulk clear the resolution - ScriptRunner built-in script missing None?
Janene Pappas
July 6, 2020
I'm attempting to clear the resolution on tickets that were re-opened. I have ScriptRunner and I thought I'd done this easily before but the dialog for the built-in script no longer has a "none" or "null" or "clear" option:Screen Shot 2020-07-06 at 3.33.06 PM.png How do I clear the resolution now?
Janene Pappas
September 9, 2020
Apparently no value is no longer an option in the bulk resolution setting.
Jeff Abbott July 22, 2022
Use None
Sachin
July 6, 2020
Hello @Janene Pappas , that's definitely a new one. So, I am hoping you have created/saved a filter for bad resolutions, then choose filter for "Filter id" and then in the second row for "New Resolution" you don't see "None" ? Is this correct?
I would try reinstall scriptrunner to see if it fixes the problem.
Janene Pappas
July 7, 2020
Yes, I have a filter that returns a list of issues that have been re-opened and the resolution was not cleared. When I click the 2nd row, the above is all I get, no "None".
I'm running Jira Cloud, so I cannot reinstall.
Like • Figueiredo_ Victor likes this
Sachin
July 7, 2020
I think it's better to get some help from https://www.adaptavist.com/contact
