How to bulk move issues to another project
Josh Pike
October 19, 2018
From the backlog view, you can click on an individual issue, and in the details sidebar, click the [...] button to "Move" the issue to another project.
This option is not available from the [...] button on the backlog list view, with multiple issues selected (where you can move to top or bottom of backlog, for instance).
Is there a way to bulk move issues from one project to another in the next-gen jira?
2 accepted
34 votes
Tuncay Senturk _Snapbytes_
October 20, 2018 edited
Hello Josh,
Yes, there is a way to do that.
  • Go to the Advanced search view and search for issues to move
  • Select the options button (3 dots in top-right corner) > Bulk Change...
  • Select the issues you'd like to perform the bulk operation on, and select Next.
  • Select Move Issues, and select Next.
More details here
Josh Pike
October 20, 2018
Thank you! I didn't realize how many more actions were possible from the search results!
Jamie Leinen
November 27, 2018 edited
Hi Tuncay,
I don't see the tools menu in the Next Gen project like we do on the issues screen in classic.  Is there a screen shot you can include.  I need to move all my epics and stories from a Next Gen project to a classic, because we can't use the Next Gen without subtasks.  Right now, I am only seeing a way to move one item at a time, and no option to bulk move.
Like • 10 people like this
Gurpreet
December 19, 2018
you need to click on search icon on the left hand side blue global bar and then click on View all issues. once you are on issue navigator page, specify your search results for your next gen projets. once you see your issues then click on 3 dots on the top right. here is a screenshot for youchrome_2018-12-20_16-11-01.png
Like • 7 people like this
Jonathan Mao March 24, 2019
What are the search parameters to select the whole Backlog in a classic project?
I want to move all the Backlog items to the To Do column in a next-gen project.
Alexander Horn
April 8, 2019
on my search results tool menu (see screenshot), there is no 'bulk change', per Gurpreet's screenshot.
So.. what is the trick to bulk move ?
(... as It's not the API)
or is it truly not possible?
View:
Like • 2 people like this
Erin Robinson April 10, 2019
Yes, I have the same limitations as Alex does above. When I click on the three ellipses, I either see Clear Sorts or No Available Options.
Maria Campbell
I also have the same limitations. I have no way to bulk move to a classic project. Next Gen totally does NOT work for me. Have been fiddling with this all morning. It's getting to be annoying. And when I create a classic project, I am still getting next gen. Why???
Like • 5 people like this
Jean-Baptiste Briere
May 2, 2019
Working work between classic projects. Thanks for the tip.
Ron McNamara
May 9, 2019
This is just another example of why Next gen projects were released waaaay too early.
Maria Campbell
May 16, 2019 edited
I did end up finding the bulk action. However, it was NOT exactly the same as before. There are definitely differences. So now I just share my original classic project workflow with new projects.
Like • Rayner Reynaldo Rincon Perez likes this
pshustak June 3, 2019
I'm still trying to determine if bulk move is supported for Next Gen projects. Can anyone confirm?
Nicole Naude June 11, 2019
My project is a classic project, and I see "No Available Option(s)" when I click on the ellipsis. Does anyone know if this is a permission issue? And if so, what is the correct permission setting to get the Bulk Change setting back?
Like • Allard likes this
Deleted user March 20, 2020 edited
I was trying to look up for the Issues & Filters Tab to filter out issues for a Next-Gen Project.. Thankfully this suggestion helped me work around it!
No wonder its been removed to declutter UI!
Thanks for the Solution! One less reason to Curse Next-Gen Projects! :)
I'm glad it helped
Elena Lo
October 15, 2022
Thank you! This answer solved so many of my issues with Jira at once. You are a great human being :)
You're welcome, I'm glad it helped.
Thank you for your kind words!
Javier
June 3, 2023
Great
Like • Tuncay Senturk _Snapbytes_ likes this
Yuval Zukerman
January 26, 2024
Thank you!!! This saved me so much work!!!
7 votes
Jason Taylor
October 1, 2020 edited
Try this to bulk move in the Next Gen version:
Go to the project with the tasks you want to move.
On the left hand navigation menu click on "Issues".
In the upper right hand side, click on the "Advanced Search" link.
in the far upper right corner, click on the "meatball menu" - the three dots. Click on "Bulk change all".
Select all tasks using the higher list checkbox.
Click on Next.
Select "Move Issues" and click Next.
Select the project you want to move the tasks, subtasks, or Epics to. Note: you may want to move based on task type so that you can maintain the type for the task in the other project.
 Click on Next.
Verify the target status and click Next.
Verify the task fields and click Next.
Conifrm the changes
Click Confirm.
G subramanyam
Thank you @Jason Taylor
Like • Chris Shaw likes this
3 votes
Manuk Shirinyan
April 25, 2019
If you don't have 'Bulk' actions in your dropdown - check your permissions.
Do you happen to know which setting would provide this correct permission?
Like • Dulce Pumareja likes this
Mo Beigi
January 17, 2020
Ensure you are a member of a group with Jira Admin permissions in admin.atlassian.com.
Ahmed Mekawy
July 9, 2023
did the admin permission fix your issue? @Nicole Naude
Sreedevi Kr
@Ahmed Mekawy  if you are admin, go to System->global permissions -> bulk change . Check whether in this permission your role/admin/user is added then only you can perform bulk operation.
Benjamin Gordon
February 22, 2021
I found how to execute a bulk move in Next Gen Jira!
  1. Click on the search bar at the top as if you were going to search for an issue.
  2. Click on "Advanced search issue"
  3. Select your issues based on the filter criteria
  4. Click on the "..." on the upper right
  5. Select "Bulk change"
Timothy Hicks
June 1, 2023
This helped me. Thanks. There is another key step, wait for the screen to select only the tasks/issues you want moved.
Shwetha.Peruri
I dont see the bulk move option in cloud jira.
How do I see it.
Nicole Naude April 7, 2020
There is a permission setting for Bulk Move now in the Global Permissions settings.  You will need to have an Admin grant you that permission before you will see the option.
Karthick M
October 31, 2019 edited
Hi There!
I would like to know if the Comments, History will be maintained in the destination project once they are bulk moved.
Ramanathan Yegyanarayanan
Yes History remains the same as it is and that move will also get recorded in history.
Like • Deleted user likes this
Maryna Omelchenko
June 10, 2019
Hi there!
I have a question related to this topic. I made bulk move from a classic project to next gen one. The problem is that the issues kept the previous parent epics. Is it supposed to work like this?
Thank you!
Prashanth August 16, 2019
How to extend/increase the bulk limit from 1000 to 2000 in jira Cloud version
Read the story
