How to call Jira API with access token from postman?
sirsendu_gope June 12, 2020
I have configured Jira software with my web app using OAuth and get the access key. Now I couldn't find anything how to call a jira api from postman using that access key. Can anyone help me on this step by step?
Sirsendu Gope
Rob Peterson
sample URL but can be any of the API documented endpoints
Rahul Kumar
June 18, 2020
Hello Sirsendu,
You need to use the token generated under authentication -> password to access API's using postman.
Basically -
1. Use the required method and endpoint in header
2. In Authentication use your atlassian id and token
3. Provide the required payload for end point
Rahul
Help us plant more trees
