I would like to change the status of the below issue without opening in a new window or by choosing "more actions" from options.
Wondering if there is a way to make the status field editable where I can pick the next desired status from the drop down.
Current Workflow:
1. Dev In progress
2. Ready For QA
3. QA In Progress
4. Ready For UAT
5. UAT In Progress
6. Ready For Release
7. Done
Hi @VP
Welcome to the community!
I do not know how you can make that field editable, but how about a work-around:
Press the period key "." to pop-up shortcuts, and then start typing the name of the target status (e.g. UAT), and when it appears in the type-ahead search, press enter to select.
Best regards,
