How to change the sprint name/ID while already running
Hans-Hermann Hunfeld
By mistaken we entered a wrong sprint ID in the GreenHopper agile board but recognized this when the sprint was already started. How can we change this?
Ok, now i got it!
In planning mode you must first click on the triangle to open the details of the actual sprint and then you get the pencil symbol to change date or name.
Thanks a lot!
Stefan Heintz
July 4, 2012
Worked perfectly, but how about changing a name of a closed sprint?
Stefan Heintz
July 9, 2012
Renjith Pillai
April 17, 2012
If you mean the name of the sprint, then you can change it while in Planning Mode, keep the mouse over the date details of the sprint and you will get a pencil icon, which you can use to edit the sprint.
No, i meant the rapid board. And furthermore i m not looking for changing some issues but rename the whole "sprint in progress".
Hopefully now it s clear what the question is...
Renjith Pillai
April 16, 2012
Assuming it is the regular one, open the Planning Board, select the version in which the issue is present, drag and drop into the correct version to the right.
Renjith Pillai
April 16, 2012
You meant Rapid Board or the regular Greenhopper?
Register now
