×Hi Team,
I have a workflow scheme which uses a old workflow for "All unassigned issue types". We would like to change a newly created workflow for "All unassigned issue types". Is there an option to do it?
Rahini
Hi @rbalamu2
In the Workflow Scheme, add the existing (inactive) new workflow to the workflow scheme.
Then, choose the mapping, i.e. "All unassigned issue types".
After confirming, you may need to map old statuses to new statuses.
Let the mapping finish and acknowledge.
You're welcome, great to hear you got it sorted out.
