How to close a sprint ?
johann bich
September 17, 2015
Here are the background information:
  • Created a project in KANBAN mode
  • Created many task / stories in it
  • Bulk change to switch to a SCRUM project
  • removed the KANBAN project
Now the issue:
  • when user that are administrator of the SCRUM project try to end a sprint, they have an error message:
    • To update this sprint you must have Project Administrator permissions for all of the following projects: 12800, Scrum Project
  • They are administrator of the "Scrum Project", but i think that the "12800" is the ID of the old KANBAN project.
  • As this KANBAN project has been removed, i cannot add them as administrator of this project
Result:
  • They can't close the sprint, and it's not good
Does anyone know about this issue ? how can i handle it ? how can I remove this error message and let the administrators of the project end their sprint without me ?
Taha Khanzada
September 17, 2015
Hi Johann,
Yes, 12800 is the project id. There is known bug that if issue is moved to another project then it is not cleared from sprint, check the workaround available in the ticket.
https://jira.atlassian.com/browse/GHS-9030
Taha
Learn more
