How to connect with Jira Cloud database?
Kishor Ghongade April 6, 2021
How to connect with the Jira Cloud database? we want to fetch some details related to login users details from Jira cloud database etc.
Nic Brough -Adaptavist-
April 6, 2021
If by "connect", you mean "log in and use SQL", you do not.  You have no direct access to it.
You have to get to your data via the application, either using the UI or REST APIs.
We wanted to fetch reports kind of data for our Jira cloud site e.g. users logged in in past N days. We wanted to check frequency of users logging-in during weekend or for last one week or for last one month. We need these details so that we can plan our Jira migration task accordingly. Can this be achieved using REST APIs? or is there any other way by which we can fetch this kind of information?
April 6, 2021
That level of tracking is not yet available in the REST APIs, but admins can see last logins in the list of users - a manual check, yes, but it's a simple one.
If you're planning a migration though, it's not really a lot of use.  You shouldn't actually be worrying about it.  You should be simply telling all your users "Migration is happening at this time, you will not have access to the old system from that point"
Like # people like this
Spencer Bartz
April 12, 2022
When will that level of tracking be available?
My company's reporting system queries multiple databases including our Jira and GitLab DBs and combines the results. If we can't even have read access to last_login_date in a DB table we're paying Atlassian to host, my company management definitely won't migrate to Jira Cloud.
Like TomA likes this
April 12, 2022
User last logged in is available in the UI already, and in Access if you're using that for accounts.
Spencer Bartz
April 12, 2022
Your answer implied there was an intention to add that level of tracking to the REST API. True or false?
As it stands, my company will NOT adopt Jira Cloud because our DBA and Business Analyst cannot access its database.
If the UI was any substitute for database queries, no one would have asked the original question.
April 13, 2022
A Jira database has always been the ultimately terrible way to try to do any form of reporting.
Now you've moved to a SaaS version of it, where the database is inaccessible so you can't do bad things with it,  it's a good thing that you have no database access, it forces you to do your reporting properly, including monitoring your user base.
Like Julian Ting likes this
James Seabrook
@Nic Brough -Adaptavist- can you advise on how to get a report of user group assignment For example:
* permission schemes to which a user group belongs
* roles on each project to which a user group has been assigned
I have set up a load of user groups, roles and projects with user groups as roles and need to be able to see what each user group has access to.
Thanks.
February 3, 2023
This is not going to tell you a lot.  The access is such a complicated mess, a simple list will be mostly unusable.
Talk to your project admins, ask what they want, and how they would like people to use their projects.
SS - Jira User
December 17, 2024
This is what my Qlik report shows:
List of epics shown when you select a fixversion and worklog month
Epic Key | task_count | done_story_count | total_story_count |  planned effort of all children | actual_logged_effort_of_epic_children | logged_effort_during_the_selected_month
With the database access and the published schema, I could do this very well. How do you suggest we go about this?
February 6, 2025
JQL can do that far less torturously, and the issue navigator results is more flexible.  I suggest not using Qlik because it's hard work and far easier to just use Jira.
