How to copy value from epic to task through the automation rule?
oleg.buzinov July 27, 2022
Hi!
Trying to make automation that copies value of the custom field (e.g. Components) from the epic to task when epic has certain changes and signs.
The problem is that when choosing a field value in a task after branching the rule, there is only the option "Copy from the current issue" and there is a suspicion that the value is copied not from the epic, but from the task into itself.
How to copy values from an epic to sub-issues?
3 votes
Walter Buggenhout
Hi @oleg.buzinov,
You are close. At your current screen, select add components from current issue. You will see a list of options magically appear. Then select copy from epic issue:
Hope this helps!
OMG, so easy! I'm terribly blind:)
Read the story
