How to count number of comments by assignee per issue with (extended) JQL
Azur Mujezinovic May 19, 2023
Hi everyone.
Does anyone know if there is a way to get a number of comments who's author is the assignee on a ticket. If possible, it would be great
Basically, I want to make sure that assignee has left at least 2 comments per issue.
Thank you in advance,
Azur
Trudy Claspill
Hello @Azur Mujezinovic
Have you installed a third party app that extends JQL capabilities? If so, which app?
Azur Mujezinovic May 21, 2023
Hello @Trudy Claspill ,
I currently have this Comment Custom Fields for Jira, but I understand that I can not accomplish my desires with this.
Before I would switch to some other add-on, such as ScriptRunner, I would like to make certain I can accomplish what I need.
Thank you,
Regards
Trudy Claspill
So far I have not found a plugin that provides a filter to select issues by the number of comments authored by a specific user.
I found an old post in the eazyBI Community that indicated it could be done with their app. That may be applicable only to self-hosted Jira.
You could use a custom field and an Automation Rule to keep track of how many comments are added by the Assignee, incrementing the count for each comment as it gets added.
In Jira Automation I know it is possible to access the list of comments for an issue with the smart value {{issue.comments} and you can drill down to see attributes of each comment, like the author, but I haven't figured out how to use that the count the number of comments per author.
Using the REST API you could get all the comments for a given issue (and a separate API call to get the assignee of the issues) and parse through the results to see if the assignee authored two or more comments.
Like Martins Vanags_eazyBI likes this
Azur Mujezinovic May 23, 2023
I have managed to make it work with custom field and Automation Rule.
In case someone would look for the same thing in the future :
- Create a custom field (Number of comments by Jira assginee)
- Add that field to screens/projects that you want
- Create an automation rule :
when : Rule is triggered on All comments
If : matches -> {{comment.author.displayName}} equals {{issue.assignee.displayName}}
THEN : edit issue fields -> {{#increment}}{{issue.Number of comments by Jira Assignee}}{{/}}
Like # people like this
Thank you for your help ! Best regards.
Paul Prata October 28, 2024
Will this allow us to create a JSM query to report on volume of comments per agent?
Beth Woods January 20, 2025
@Azur Mujezinovic do you still have this running? Can you send a screenshot of the edit field settings you have configured? Are you using advanced settings?
Hey @Azur Mujezinovic
I'm Martins from eazyBI support team.
You could explore the solution with pre-calculated field imported in the eazyBI app
https://community.eazybi.com/t/calculating-the-number-of-comments-by-specific-user/1788/2
Martins / eazyBI
