×Hello,
On the ticket parent, I would like to create a custom field named "Subtask open"
==> it is ok for that, I know how to ake that
I would like to initialize an automation rule in order to calculate how many subtask are on a specific status like "dev done" or "to test"
I already use this calculation : {{issue.subtasks.size}}
but i don't know how to update with a specific status.
Do you know if it is possible please ?
@Aurélie Pilette I suggest using something like this:
{{issue.subtasks.status.name.match(".*(Done).*").size}}
Replace Done with your status name.
I hope it helps
Learn more
