×Hi guys,
I want to create date dependency for all the Subtasks
for eg.
Subtask 1 1st jan
Subtask 2 2nd jan
Subtask 3 3rd jan
Subtask 4 4th jan
so incase if the "Subtask 1" is delayed then automatically subtask 2 date should change to 3rd jan and same with other subtasks
and also need to insert a condition
1) all the subtask should start one after another
2) if i mark subtask 3 transission to "not requirded" then i can start other subtasks
how can i achive this
kindly help
Hi @Yash Raj - Here's a sample of how this could work:
Here's a quick explanation - I'm using Due Date field as an example:
I'd need a little more context into what you mean by your other condition:
if i mark subtask 3 transition to "not required" then i can start other subtasks
hey @Mark Segall thanks for your response
i want your 4th Point to be automate...
for eg. if number of days increases in particular subtask then it should also delay other subtasks dates.. like wise every subtask is dependend on other subtask
So you're wanting to capture that if say, sub-task1 is delayed by 4 days that all of the others are delayed by 4 days as well?
If this is the case, you would need some business logic to identify how many days to delay for each sub-task, branch into each sub-task, and then update the due date accordingly.
thanks for your quick response @Mark Segall
actually we dont know how much time/date delayed. so when ever the delay we update the delay time, the remaining subtask delay time should automatically change.
