I have just created a Next-gen project nd have created few stories in it and an Epic too but I don't find any option where I can link stories to the Epic. Help please.
Hi @prashantgera,
The most practical way to add stories to Epics is to start from the Epic and then add them as child issues.
However, when you created a story without an Epic linked to it, open that story in detail view. Then, from the title bar you can select Add Epic:
In the screenshot above, you'll notice the option at the top, to the left of the issue key.
Hope this helps!
