How to create Jira automation on a field with math expressions
Bijal Patel September 14, 2023
For example:
A = (( X + Y + Z ) / B )
All of the fields are numerical fields.
David Blank
September 14, 2023
Hi @Bijal Patel !
This should just be as easy as adding the fields you want to sum and the mathematical operator (+ and / in this case). So it could look something like:
Rule Trigger: Record Change to fields X,Y,Z
Action: Update Record: Choose your field( Field A)
In the update field use: {{#=}}{{issue.fieldx}} + {{issue.fieldy}} + {{issue.fieldz}} / {{issue.fieldb}}{{/}}
September 14, 2023
Hi @David Blank
I believe you are missing some parentheses in that expression if you want to match what the question asked.  Thanks!
Like # people like this
@David Blank @Bill Sheboy That worked. I just had to tweak it little bit.
i.e.
{{#=}}({{issue.fieldX}} + {{issue.fieldY}} + {{issue.fieldZ}}) / {{issue.fieldB}}{{/}}
Thank you for the prompt reply :)
Like Paul Banfield likes this
David Blank
September 14, 2023
Thank you @Bill Sheboy for catching my error!
@Bijal Patel happy to hear it! If I answered your question completely would please mark my answer as accepted so that others with the same question know it worked?
Like Stefan Salzl likes this
Stefan Salzl
Hi @Bijal Patel
i recommend to check out the documentation page for math expressions for jira smart values:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-math-expressions/
In case there still open questions don‘t hesitate to ask.
Best
Stefan
